goldmnr2001
#1 Posted : Wednesday, August 12, 2009 1:14:12 PM(UTC)
goldmnr2001
How do i check my thermal cut-off to see if its bad?? i checked for continuity and got nothing??is this the proper way to see if its bad??
applianceman
#2 Posted : Thursday, August 13, 2009 3:58:00 PM(UTC)
applianceman
[FONT='Times New Roman']Yes, it is open so it is bad. [/FONT]Clothes Dryer Repair Guide
#3 Posted : Friday, August 14, 2009 2:56:25 AM(UTC)
You found your thermal fuse open. Comes as a kit 279816. Thermal fuse goes near the top of the heater housing, overload thermostat near the bottom
I would also check for a bad cycling thermostat on the blower housing and check your ducting fo a lint clog. You can check your cycling thermostat in the oven, should open up at the marked temperature, usually 145- 155 degrees.
