2 Pages12>
gumbo2000
#1 Posted : Monday, January 14, 2008 6:02:04 PM(UTC)
gumbo2000
My dryer recently stopped working. When I tried turning it on, it would just make a buzzing sound. The drum would not spin. I checked the breaker and the lint trap which looked fine.
In an attempt to try to narrow down the problem, I had my wife press in the door switch, gave the drum a spin by hand, and hit the start button. The dryer started and continued to run until my wife let go of the button.
The dryer now seems to be working fine. It will start just as before (without spinning it by hand). It looks to be heating up fine and we've opened/closed the door and restarted it several times.
Any thoughts as to what the problem might have been? Should I keep an eye out for something to fail in the near future?
In case it matters, I will also add that I replaced the belt, drum slides, drum bearing, and heating element back in April, 2007.
Thanks in advance for your help!
Bob
ripleys
#2 Posted : Monday, January 14, 2008 6:18:48 PM(UTC)
ripleys
The newer GE dryer motors are common for lint build up in the motor at the motor switch. If you get the dryer apart again use a vacuum and small paint brush or compressed air and blow out the motor. Make sure you clean your external vent frequently and do not use flexible vinyl ducting.
Hope this helps and there is no need to replace the motor anytime soon.
gumbo2000
#3 Posted : Tuesday, January 15, 2008 6:33:19 PM(UTC)
gumbo2000
Thank you very much for the fast reply! I will say that we don't clean the external vent as often as we should so I will keep a better eye on that. I'll also give it a good cleaning. Even without, it dried another load tonight.
Thanks again for the help.
csideco
#4 Posted : Sunday, August 30, 2009 5:10:47 PM(UTC)
csideco
Thank you sooooo much for posting your GE dryer issue. Because of your post, we were able to get our dryer working again as well:)
calhounind
#5 Posted : Thursday, January 7, 2010 10:12:23 AM(UTC)
calhounind
Yes, thank you so much. I was having the exact same issue. After holding the door switch and turning the drum by hand, it fired right off. I did smell something burning immediately after it started but it only lasted about 30 seconds or so. I figure it might have been some lint being burned off.
pijacobsen
#6 Posted : Saturday, March 6, 2010 9:50:21 AM(UTC)
pijacobsen
I had the exact problem noted above, and like csideco, this forum fixed it immediately saving me lots of grief and possibly lots of money. Plus my wife thinks I'm a genius. Thanks again, I will go to this site next time something breaks or if I need a part.
cgallagher9
#7 Posted : Wednesday, February 1, 2012 1:04:57 PM(UTC)
cgallagher9
Had the problem...called Sears. Wanted $203...to fix which included a one year warranty...big deal...spent i think 600 only 3 1/2 years ago and had a 3 year warranty...of course that expired...thanks man.
krei825
#8 Posted : Monday, May 7, 2012 10:16:22 AM(UTC)
krei825
Had the same issue, solution worked perfectly. Thanks!
Yalvausa
#9 Posted : Tuesday, December 17, 2013 8:08:22 AM(UTC)
Yalvausa
I called my sister as she was hauling her dryer off to get repaired, which was told by a repairman that it sounded like it was the motor. In an attemp to help I googled the problem and asked her if she would like to try it and she agreed.... She called me ten minutes later and I couldn't believe my ears when she said it WORKED and her dryer was running again... She insisted I posted the good news!!! Lol!! THANK YOU!!!
roxyz
#10 Posted : Sunday, January 26, 2014 10:42:50 AM(UTC)
roxyz
The internet is amazing. We have wet clothes hanging up all over the house and have been talking to Sears about coming to do a repair...and I decided to google it just to see...and this solution WORKS!!! Thanks so much!
2 Pages12>
