taylorjr.john357
#1 Posted : Tuesday, August 11, 2009 6:44:38 PM(UTC)
taylorjr.john357
:( my frigidaire dryer model#fde7970ew2, drum turns but no heat. what's the possible causes? can i test heater assembly and related parts with my fluke 112 multimeter,and what should the readings be for the parts i test?[EMAIL="taylorjr.john358@yahoo.com"][/EMAIL]
taylorjr.john357
#2 Posted : Wednesday, August 12, 2009 10:09:59 AM(UTC)
taylorjr.john357
Originally Posted by: taylorjr.john357 Go to Quoted Post
:( my frigidaire dryer model#fde7970ew2, drum turns but no heat. what's the possible causes? can i test heater assembly and related parts with my fluke 112 multimeter,and what should the readings be for the parts i test? my email address is, taylorjr.john358@yahoo.com
need too hear from the pro's asap.
#3 Posted : Wednesday, August 12, 2009 1:11:33 PM(UTC)
The first thing I would do is check for 240 VAC at the dryer power outlet. The motor needs only 120 VAC while the heating element needs 240 VAC.
Then, according to the wiring diagram, you have to check for continuity the following parts in the heating circuit:
1. Control thermostat (#15 on the diagram)
2. High limit thermostat (#33 on the diagram)
3. Heating element (#15 on the diagram)
Any of them with the "open" circuit reading should be replaced.
- The control thermostat Part number: AP2106564
- The high limit thermostat Part number: AP2131477
- The heating element assembly Part number: AP2107129
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FDE7970EW2 | AppliancePartsPros.com
P.S. Your meter should be good enough.
Guest (5)
Mr. Taylor (Dryer Repair)
by taylorjr.john357 8/10/2009 1:06:40 PM(UTC)
