tedmueller7
#1 Posted : Tuesday, August 11, 2009 2:44:24 PM(UTC)
tedmueller7
I have a leak in the coil on the freezer on my 3.0 cu/ft fridge. Is there any way I can fix the leak or get a replacement freezer coil.
magician59
#2 Posted : Tuesday, August 11, 2009 6:36:21 PM(UTC)
magician59
The most common procedure is to replace the entire coil. If you feel you can effectively solder the aluminum, it can only cost you the time, and a couple charges of refrigerant, to see if you're successful.
