JohnMathapha
#1 Posted : Monday, January 14, 2008 3:41:25 PM(UTC)
JohnMathapha
Hi All,
I need help identifying which parts to purchase. I have a 2 year old washer that just leak from the bottom when it's running. I've checked the drainage and inlet line and it's ok. I looked underneath the washer and notice water was leaking from middle of the tub. I think it's the sump pump gasket or the volute seal. Any suggestion?
Also, what's a sump tab and what does it do or suppose to do?
Any help would be appreciated....
John
#2 Posted : Tuesday, January 15, 2008 3:12:45 PM(UTC)
Hi John,
In order to provide the most accurate advise I need the complete model number of the dishwasher. The number you posted is the serial number.
JohnMathapha
#3 Posted : Tuesday, January 15, 2008 4:08:15 PM(UTC)
JohnMathapha
model: GU1200XTLS1
serial #: FP0509208
#4 Posted : Wednesday, January 16, 2008 9:09:34 AM(UTC)
Hi John,
A sump tab is a part of a locking mechanism.
Both parts you mentioned could cause a water leak. The best thing is to remove the dishwasher from the cabinet to find out which part is wrong exactly.
- Here are the break down diagrams for the Whirlpool dishwasher Model GU1200XTLS1
Guest (4)
