when i turn on my maytag dishwasher it just hum and will do nuthing
Originally Posted by: willie3980  when i turn on my maytag dishwasher it just hum and will do nuthing Can you determine whether it's a motor hum, or the water valve humming trying to let water in? If it's the motor humming it sounds like the machine isn't filling with water. Can you provide any more detail?
there no water going to it i have it apart and there is no blockage i think the huming is comeing from the motor
Originally Posted by: willie3980  there no water going to it i have it apart and there is no blockage i think the huming is comeing from the motor You're going to need a volt meter to determine whether you've got voltage going to the water valve during the fill time. Also make sure the float inside the dw is in the down position and coming into contact with the float switch. You should hear the float switch click when raising and lowering the float.
where is the float switch at i put the volt meter onthe water valve and that is working the motor is get hot to
Originally Posted by: willie3980  where is the float switch at i put the volt meter onthe water valve and that is working the motor is get hot to If you have voltage to the water valve, and it isn't filling, the valve is bad. That is as long as water is getting to the valve from your source. If the float was at fault you wouldn't be getting voltage at the valve. Not sure I understand what you're asking about on the motor.
when it filling it still hum and the motor is geting hot
Originally Posted by: willie3980  when it filling it still hum and the motor is geting hot i got water to go in but its like the motor is bad it just hums if i try to trun the motor when it on it gos i1 trun then stops
