After using the water dispenser on the freezer door, the water drips for a little bit, about 2-3 tablespoons. There is no leaking to the ice dispenser and the water filter hasn't been changed recently. Not sure if the problem is with the Valve-water, triple solenoid, one of the Tube-water inlet valves or possibly somewhere else. Any ideas?
Kenmore Model # 253-53622300
