jim1944
#1 Posted : Monday, January 14, 2008 11:28:01 AM(UTC)
jim1944
I took the door apart today and had trouble figuring how the latch "link" fits in the latch mechanism when reassembling. I thought that I had it in correctly, but when I closed the door, it won't open again.
Any advice??:(
techman222
#2 Posted : Monday, January 14, 2008 5:12:44 PM(UTC)
techman222
The only way is to pull out the dishwasher unhook the latch and then unscrew the door panel. If the unit is secured good in the hole your out of luck. Your going to have to brake the door lock.:eek:
#3 Posted : Monday, January 14, 2008 6:50:05 PM(UTC)
You may be able to slip a putty knife, or butter knife under the door latch and pry it off. Worth a try.
