38dean
#1 Posted : Monday, August 10, 2009 7:42:12 AM(UTC)
38dean
My Superba Kitchenaid ice maker is making ice, but is not ejecting the ice. The plastic fingers rotate to the point where the ice is sitting on top of the ice chipper, but not falling to the ice bin. The optics of the ice maker work normally, (blink when door open, steady light when flapper is shut.). I am trying to determine if I need to order a thermostat, ice mold or new ice maker?
Thanks,
Dean
applianceman
#2 Posted : Monday, August 10, 2009 4:00:41 PM(UTC)
applianceman
From you description I think you need this part
Part Details - WHIRLPOOL MOTOR-MODL, part number: W10190935
Assuming the rake (fingers) are not binding somehow. Whirlpool Icemaker Repair Guide
38dean
#3 Posted : Wednesday, August 12, 2009 7:14:48 AM(UTC)
38dean
Repairman,
Thanks for the advice and referencing the repair guide. I will follow the repair guide recommendation and test to see if the module or thermostat need replacing.
#4 Posted : Wednesday, August 12, 2009 1:56:55 PM(UTC)
Originally Posted by: 38dean Go to Quoted Post
Repairman,
Keep in mind - there is relatively low success rate on ice makers repair. Very often it is more cost efficient and much more reliable to replace the whole ice maker.
- The ice maker Part number: AP3182733
Guest (4)
