phitter38
#1 Posted : Monday, August 10, 2009 2:32:28 PM(UTC)
phitter38
element doesn't shut off except in last 2 min. of a cycle
sidfink43
#2 Posted : Wednesday, August 12, 2009 6:37:26 AM(UTC)
sidfink43
It may be an electrical failure through the motor, but more likely a failure of the thermostats. Because they may be failing in the closed position there is no easy way to check them out.
I would call APP for a price check and availability if you want to change them out. No guarantee of a fix, but a good possibility.
Good luck.
