My Bosch is exhibiting the same problem that I see posted by others, it gets part of the way through the cycle and then stops advancing. It is probably a heating problem. I understand from previous posts that the control module is suspect. So, I have removed it and inspected it for burned solder joints. However, I do not see any problems with these joints. This leads me to wonder whether or not it is actually the heater element.
So, now my question. How best do I verify that the heater element is fine? I understand that I could measure the current to the heater while it is trying to heat (it ahould be 11A) but if I don't get the expected current, doesn't that mean it could be the heater or the control module? Short of removing the heater element (which I understand is deep inside teh unit) how do I verify that it is okay?
Originally Posted by: Greg in Sudbury  My Bosch is exhibiting the same problem that I see posted by others, it gets part of the way through the cycle and then stops advancing. It is probably a heating problem. I understand from previous posts that the control module is suspect. So, I have removed it and inspected it for burned solder joints. However, I do not see any problems with these joints. This leads me to wonder whether or not it is actually the heater element.
Thanks Try this troubleshooting file. Check the Resistance. Great document!
