fumey
#1 Posted : Thursday, August 6, 2009 8:41:11 PM(UTC)
fumey
replaced the control board a couple years ago , seemed okay for a while , recently freezer temp spikes to 16 degrees , mullion gets hot....again :mad:... Seems to be a common problem with this fridge , at least thats what a search on the net indicates. Is there any definitive fix ? Compressor? Condenser? Is it low on freezer juice? Help........
ApplianceJunk
#2 Posted : Friday, August 7, 2009 6:05:02 AM(UTC)
ApplianceJunk
How old is this refrigerator?
fumey
#3 Posted : Friday, August 7, 2009 1:00:15 PM(UTC)
fumey
We bought it in '04...
#4 Posted : Friday, August 7, 2009 1:08:07 PM(UTC)
Seems like a bad condenser motor or the control board again, best to stick a fan on it to cool it down.
If it is a bad control board it's best to stick a 1000 joule surge protector on the fridg outlet, just make sure it's designed for a fridg, will say on the box, available at Lowe's
fumey
#5 Posted : Saturday, August 8, 2009 8:41:29 AM(UTC)
fumey
Did find out that the fan does run ,
does this narrow things down to the condenser?
#6 Posted : Saturday, August 8, 2009 9:26:33 AM(UTC)
We need to know what is or isn't running when failure happens.
fumey
#7 Posted : Sunday, August 9, 2009 3:50:31 PM(UTC)
fumey
...temp is rising , fan is running...
Condenser motor?
AIMANNY
#8 Posted : Sunday, August 9, 2009 3:53:26 PM(UTC)
AIMANNY
Are the condenser coils dirty.
fumey
#9 Posted : Sunday, August 9, 2009 4:04:25 PM(UTC)
fumey
No , that was the first thing we checked.........
fumey
#10 Posted : Monday, August 10, 2009 10:56:17 AM(UTC)
fumey
bump......
Guest (4)
