Joe Mahacek
#1 Posted : Thursday, August 6, 2009 10:58:51 AM(UTC)
Joe Mahacek
My dryer runs fine but it will not cycle down. Whichever setting you start it on, it just stays there and will run until you stop it. It will not cycle down. What is causing this and is it an easy fix?
#2 Posted : Thursday, August 6, 2009 4:11:17 PM(UTC)
Joe,
If it does heat properly then the problem most likely is a bad timer.
- The timer Part number: AP3131943
