Every time we use the water dispenser, water squirts out of two or three pin size holes in the water dispenser assembly in the fresh food section (part # AP3205548, diagram # 810. My question is should I replace the dispenser assembly and if so, do I need to order any other parts.
You probably have a bad 1/4 inch plastic water line in the door fountain assy., just check.
Did you replace the water dispenser assembly? On my fridge, the hoses that run into and out of it are cracked. The the water dispenser assembly looks like it needs a special tool to melt/shrink the ends onto the inlet and outlet hoses. How did you install yours?
thanks
