dexann
#1 Posted : Wednesday, August 5, 2009 2:49:54 PM(UTC)
dexann
Dryer drum seems to wobble as it spins. Makes vibration sounding noise while drum is spinning probably do to drum wobbling.
sidfink43
#2 Posted : Friday, August 7, 2009 1:21:16 PM(UTC)
sidfink43
You are going to have to open it up and turn the drum by hand to see if you can source the problem.
Most likely the rollers, here are the parts.
Part number: AP3098345
Good luck.
dexann
#3 Posted : Friday, August 7, 2009 2:12:27 PM(UTC)
dexann
I replaced rollers and it seems to be running fine.
sidfink43
#4 Posted : Friday, August 7, 2009 2:23:10 PM(UTC)
sidfink43
Great, glad it is working well for you
