how do you get to door switch to replace
Hi Jim
1.Take off the bottom panel and remove the top panel.
2. Trace the wires from the door switch up to the top and disconnect the plastic connector
3. Reach up under from the bottom and hold the switch while you take out the screws that hold it in.
That should do it, let us know if you need more info.
Good luck.
the kit comes with new weights for drum is it nessary to replace weights
