AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Clothes still to wet to Dry after several attempts to spin
Clothes still to wet to Dry after several attempts to spin.
At one point we thought it was something in the water pump removed all hoses at the bottom and cleaned them out still to no avail we had the same problem. Need any info that you may have and or pics to try to fix problem.If this keeps on i'll be back on here asking advise about my dryer lol ;) thanks lane
More info is needed. Does the tub appear to be spinning fast enough?
I would pull the front panel off and check the belt, also check above the tranny for a bad tub seal, look for water damage.
Washer Repair
