Rtexas
#1 Posted : Monday, August 3, 2009 5:26:31 PM(UTC)
Rtexas
How do you remove the Front Cover Assembly[part# AP3126702]?
Water, ice dispenser and light does not work on the refrigerator. Unit is 7yrs old. Connector below the door has power so it must the control or swithch inside.
How do you remove the Cover? I don't want to break it.
-Any suggestion on what part is needed to make it work? thks.
KitchenAid Supra model side/side, 24in counter depth unit
#2 Posted : Tuesday, August 4, 2009 5:58:17 PM(UTC)
You can use the instructions attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSCS25FKSS01 | AppliancePartsPros.com
File Attachment(s):
Ice and water dispenser.doc (435kb) downloaded 140 time(s).
KevinRoth
#3 Posted : Sunday, June 20, 2010 3:54:24 PM(UTC)
KevinRoth
Thanks Gene.
#4 Posted : Sunday, June 20, 2010 8:22:11 PM(UTC)
You are welcome Kevin.
