I am trying to repair the Middle Spray Arm and Supply Tube. The connecting piece that fastens to the tube by a screw fractured.
Originally I ordered part # 3378144, but it is only the supply tube and does not include the connecting piece. I am also able to locate part #337147 that is the kit, but from the picture do not see the connecting part included in the kit. Before I re-order the kit and return just the tube, I want to make sure this is the right part.
From the picture it also appears the connection may be redesigned, that no longer requires the connecting piece fastened by a screw. Is this correct?
