huntress
#1 Posted : 16 years ago
huntress
The above oven is less than two years old and worked perfectly until after we ran a self-clean cycle. After the cycle completed, it would not turn on. There was a code on the panel, but not knowing what it meant, we just cleared the code (dumb thing to do!). We have disconnected the oven (convection) for several minutes and then reconnected, but still no luck.
How do we recreate the code?
Thank you!
Dan O.
#2 Posted : 16 years ago
Dan O.
Pressing and holding the "CANCEL" key for 5 seconds should display the previous fault code or "F0" (maybe "F0 E0") if none remains in memory.
I do not know if disconnecting power would have cleared the code from the control memory. :cool:
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
huntress
#3 Posted : 16 years ago
huntress
Many thanks for the information. Will try now.
Carolyn
huntress
#4 Posted : 16 years ago
huntress
Just tried to press and hold down the Cancel key, but no luck....nothing was displayed.
Any other suggestions?
Thank you, again!
