JK030150
#1 Posted : Wednesday, January 9, 2008 5:22:12 PM(UTC)
JK030150
Replaced bake element as it sparked and started on fire, then no longer worked (everything else worked before replacing the element). Once the new element was in, however, nothing works but the clock. The burners and both elements do not work at all. Opened the control panel and nothing appears to be fried. Tomorrow I will pick up some new fuses for my breaker and try that. Any other ideas?
#2 Posted : Wednesday, January 9, 2008 6:28:51 PM(UTC)
Most likely the problem with your range is one of two circuit breakers is "off".
While the heating elements needed 240V (both lines), the clock needs only 120V supplied by the one line.
Best regards.
JK030150
#3 Posted : Thursday, January 10, 2008 2:01:58 PM(UTC)
JK030150
Thank you, Gene.
Once I replaced the fuses, things appear to be working fine!
#4 Posted : Thursday, January 10, 2008 3:02:04 PM(UTC)
I'm glad you were able to fix it.
Best regards,
