chrisr
#1 Posted : Friday, July 31, 2009 2:24:34 PM(UTC)
chrisr
I punctured the tray at the bottom of the freezer. Is this replaceable? It is flat and curves up at the back, where it is attached to the rear wall with two round headed fasteners. I'm not sure if this is the main cooling unit or if it's just for the freezer. Thanks in advance.
#2 Posted : Friday, July 31, 2009 3:29:52 PM(UTC)
The model number you posted does not come up. Verify and repost it.
chrisr
#3 Posted : Friday, July 31, 2009 6:19:46 PM(UTC)
chrisr
Hey Gene, I noticed that the Sanyo brand doesn't appear in the drop down and the model is not on the Sanyo website. The model no. is sr 4431-s, I'm taking that straight off the label. Thanks.
#4 Posted : Saturday, August 1, 2009 2:30:35 PM(UTC)
After some searches I found that this is a small (4.4 cubic foot) under-the-counter refrigerator with the freezer compartment inside. The body of the freezer is the evaporator at the same time. If you punctured it then Freon leaked out through this hole. This refrigerator is very inexpensive and is not worth any repairs.
chrisr
#5 Posted : Sunday, August 2, 2009 10:12:19 PM(UTC)
chrisr
thanks, Gene, thats about what I figured.
