novven
#1 Posted : Friday, July 31, 2009 12:02:24 PM(UTC)
novven
I have a GE Nautilus dishwasher and it is not going through the cycles. It is draining and running fine but it just keeps on running and running stuck doing the same thing unless it is filling up. It has a dial on it and it does not appear to be moving on it's own.
#2 Posted : Friday, July 31, 2009 4:17:15 PM(UTC)
What is the complete model number of the dishwasher?
novven
#3 Posted : Saturday, August 1, 2009 5:53:46 AM(UTC)
novven
The model # is GSD2600G02WW
#4 Posted : Saturday, August 1, 2009 2:55:16 PM(UTC)
Open the control panel and check the switches on the left side. Probably one or two of them are fried.
If there is nothing wrong then the problem most likely is a bad timer.
- The switch kit Part number: AP2617405
GE Nautilus Dishwasher (Dishwasher Repair)
by Curt Brennan 7/30/2015 10:38:58 AM(UTC)
GE nautilus dishwasher (Dishwasher Repair)
by golfingman 4/18/2014 3:37:08 PM(UTC)
GE Nautilus will not drain (Dishwasher Repair)
by hecven101 8/29/2013 6:21:19 AM(UTC)
GE Nautilus Leaking (Dishwasher Repair)
by brazilianldsjaguar 1/2/2013 2:04:09 PM(UTC)
GE Nautilus Fills with water, then won't run. (Dishwasher Repair)
by SBR65 6/3/2012 5:14:40 PM(UTC)
GE Nautilus won't drain - standing water (Dishwasher Repair)
by cherylbland 1/6/2012 6:22:24 AM(UTC)
Ge Nautilus (Dishwasher Repair)
by AnnMatilda 10/21/2011 1:46:49 PM(UTC)
GE nautilus dishwasher doesn't push water to top arm and won't drain (Dishwasher Repair)
by ole joe 7/19/2011 5:50:24 PM(UTC)
GE NAUTILUS Not pumping out completely (Dishwasher Repair)
by HoundDoggy 3/17/2011 1:45:33 PM(UTC)
GE Nautilus won't start (Dishwasher Repair)
by Olivematt 3/1/2011 5:46:04 AM(UTC)
GE Nautilus (Dishwasher Repair)
by dre2142 1/31/2011 3:44:10 PM(UTC)
GE Nautilus odd model number (Dishwasher Repair)
by macdouga 1/22/2011 3:33:03 PM(UTC)
GE Nautilus Dishwasher making noise (Dishwasher Repair)
by Krowell 12/10/2010 6:27:22 AM(UTC)
by Jess9375 11/30/2010 3:32:34 PM(UTC)
by thomasc 9/10/2010 12:27:26 PM(UTC)
