lt3
#1 Posted : Tuesday, January 8, 2008 5:05:46 AM(UTC)
lt3
gene and okbobcats thanks for your help ! gene i found a 1and a half inch paint brush , a wash cloth , sissors , a screw driver and 3 hand fulls of lint in the bottom of the lint trap by the blower . well now she dryed one load and now she has no power up stairs by the on button or at the timer . can you guys find it in your hearts to help me out again ? THANK YOU in advance for your time , and your advice
lt3
#2 Posted : Tuesday, January 8, 2008 6:15:08 AM(UTC)
lt3
i've also checked i have power in on the cord , down to the one side of the thermal fuse but nothing going up to the timer or the push on button
fyxer
#3 Posted : Tuesday, January 8, 2008 9:20:04 AM(UTC)
fyxer
if the thermal fuse is ok and the dryer will not start check the door switch and the door switch actuater.
lt3
#4 Posted : Tuesday, January 8, 2008 9:27:02 AM(UTC)
lt3
only one side was hot the other side was dead thanks
lt3
#5 Posted : Wednesday, January 9, 2008 3:57:43 AM(UTC)
lt3
thanks that worked for one load ! then she died again with about 10 minutes left on the timer . what should i check now , other than current sale prices . this is like becoming a quest , fix this dryer or die trying . can you help ,or do i fold em and give in to the wifee ?
#6 Posted : Wednesday, January 9, 2008 6:52:42 PM(UTC)
According to the manufacturer instructions if the thermal fuse blown, it has to be replaced together with the cycling thermostat.
- The part number for the thermal fuse is AP3132867
- The part number for the cycling thermostat is AP3115922
Good luck.
lt3
#7 Posted : Thursday, January 10, 2008 3:59:30 AM(UTC)
lt3
thank you for your time and advice , im going to give it a shot tonight
#8 Posted : Thursday, January 10, 2008 8:21:33 AM(UTC)
Keep me updated.
