bs81753
#1 Posted : Friday, July 31, 2009 1:05:12 PM(UTC)
bs81753
Igniter works for a few weeks them stops working for a few weeks. Can still light with a match. Maybe needs new igniter module?
magician59
#2 Posted : Friday, July 31, 2009 1:17:05 PM(UTC)
magician59
Check to make sure the ignitor electrode is clean and dry. Check the wires for loose connections or continuity to ground. If all this checks out OK, then suspect the spark module.
bs81753
#3 Posted : Friday, July 31, 2009 1:24:13 PM(UTC)
bs81753
If one electrode is loose, will all four all not work? What part of it should have continuity to ground?
magician59
#4 Posted : Friday, July 31, 2009 2:44:05 PM(UTC)
magician59
If you find continuity from any of the electrode leads to ground, you need to replace the wire(s).
