captom
#1 Posted : 16 years ago
captom
water drips into main cabinet during defrost cycle. defrost drain line is clear. any ideas ie. defrost timer or control
#2 Posted : 16 years ago
How did you check the drain line? Have you removed the rear panel in the freezer?
captom
#3 Posted : 16 years ago
captom
I poured hot water in the back of the freezer compartment after I took the back panel inside the freezer off. water ran out of the bottom of the fridge into the evaporator pan.
#4 Posted : 16 years ago
There suppose to be something wrong in the freezer compartment or with the drain line (a hole somewhere or something like that). There are no other ways for water to get into the fresh food compartment.
captom
#5 Posted : 16 years ago
captom
Thanks Gene I'll try and find it next time I'm at that house. It just sort of drips in where the air blows into the main cabin when the defrost cycle runs. I think some areas like that panel I took off get frosted and the drip into the fridge during the defrost.
#6 Posted : 16 years ago
One more thing to check. If the door seal is broken and the door is not sealing properly then it could be a condensation.
captom
#7 Posted : 16 years ago
captom
Gene, One time when I was at the house I noticed that the ice in the bin had melted and refroze. Would that mean anything to you? Thanks
magician59
#8 Posted : 16 years ago
magician59
this could be an indication of a defrost timer problem.
#9 Posted : 16 years ago
There are a few different things which can cause it. Watch it closer and post the results.
water in fridge (Refrigerator & Freezer Repair)
by iggy216 13 years ago
leaking icemaker water in fridge (Refrigerator & Freezer Repair)
by pgtek2001 13 years ago
Water In Fridge (Refrigerator & Freezer Repair)
by GIFFORD95 17 years ago
