Bob Morgan
#1 Posted : Monday, July 27, 2009 8:44:26 PM(UTC)
Bob Morgan
The clothes get dry and the dryer keeps running for a long time. It does stop sometimes but runs to long. I even set it to less dry and it runs for over 1 1/2 hours. When I checked the clothes they were dry and it was only half way to the stop point.
sidfink43
#2 Posted : Thursday, July 30, 2009 12:56:03 PM(UTC)
sidfink43
Check and see if it does this in all cycle, and let us know the results, along with your full model number
Bob Morgan
#3 Posted : Thursday, July 30, 2009 5:21:25 PM(UTC)
Bob Morgan
We never use the timer cycle. We always use the auto dry cycle. The model number is DE312. Series 05
sidfink43
#4 Posted : Friday, July 31, 2009 5:08:56 AM(UTC)
sidfink43
Hi Bob
I understand that you only use the auto cycle, but we need to know if the problem is in the timed cycle also, which points to a timer problem, or if not, the problem might be in the moisture sensor area.
