Hello all i have a Frigidaire affinity that keeps giving me a error code of e68 it has done it in the past but it went away this time it wont go away and i cant dry my clothes any help is greatly appreciated.
thanks in advance zach
Ok, you need to locate the tech sheet (look inside the rear service panel or behing the front panel) and perform the tests for your error code.
The machine thinks one of the buttons is sticking. It may be, which is why you get an intermittent result and now it may be stuck permanently.
If no button is stuck you will probably have to replace the main control board, but hopefully that will not have to take place.
Good luck.
thanks ill take a look at it
