Richard Nelson
#1 Posted : Thursday, July 30, 2009 9:08:56 AM(UTC)
Richard Nelson
When i put clothes in the dryer and hit the normal start all that happens is the panel shows sensing, but it doesn't start. Ordered new sensor harness and sensor, changed the harness but the sensor is on back order, however the one on it is almost new so i am not sure what's wrong. HELP
#2 Posted : Thursday, July 30, 2009 11:38:03 AM(UTC)
Perform the diagnostic tests as instructed in the Tech sheet (attached to the reply) and post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GEX9868JQ0 | AppliancePartsPros.com
File Attachment(s):
ssudbury
#3 Posted : Tuesday, February 1, 2011 6:25:57 PM(UTC)
ssudbury
Perform the diagnostic tests as instructed in the Tech sheet and post the results.
I have this exact problem, but I cannot access that Tech Sheet without buying a membership to the linked website, and it is quite costly. Do you have an alternative method of getting that Tech Sheet?
#4 Posted : Wednesday, February 2, 2011 12:49:31 PM(UTC)
The tech sheet is now attached to the previous post, so you can download it.
nelson (Washer Repair)
by DWNELSON 10/14/2010 1:23:30 PM(UTC)
Roy Nelson (Oven Repair (including Ranges and Cooktops))
by Roy Nelson 4/16/2010 6:18:20 AM(UTC)
