My Wash Machine Leaks From Under Tub At Center. I Am Told The Mounting Stem (kit) And Tub Bearing (kit) Both Need To Be Replaced. Is It Necessary To Replace Both When Replacing One? Or Is It Just Saving A Headache Down The Road To Replace Both At The Same Time? Is This Repair Complicated Enough To Pay Repairman $300.00 To Do, Or Can It Be Done By My Mechanically Inclined Husband?
According to the manufacturer instructions in case of water leak both of these parts have to be replaced. Also a spanner wrench is needed to complete repairs. The mounting stem kit comes with the installation instructions and the Service manual might help as well. - The mounting stem kit Part number: AP4390013
Gene, Thank you so much for the reply and the info! MUCH appreciated. One other question, in looking through the instructions, Maytag center seal grease is mentioned to be used in a couple of different applications. Where do I get it????? Thanks
Originally Posted by: Gene Central seal grease Part number: AP4285971
GENE, i ORDERED THE PARTS, THEY SHOULD BE DELIVERED TOMORROW. The cust. serv. person said the Maytag center seal grease was in stock, so I ordered it, but it was back ordered after all. The "OTHER" Center seal grease you recommended was actually silicon sealant in the picture. I s the Maytag center seal grease actually a grease ( AN ACTUAL GREASY SUBSTANCE THAT DOESN'T DRY) or is it silicon sealant ( which does dry to be a rubbery type sealant, the kind I probably already have)? Thank you again for your help, you are a lifesaver!
