drthomas123
#1 Posted : Thursday, July 30, 2009 6:02:15 AM(UTC)
drthomas123
Hello. I have a Frigidaire AquaSurge with SpeedClean dishwasher (Model #FDB4315LFC0) that is 2 years old. All the cleaning cycles work fine, but when the cycles are done, the motor keeps running, and to make it stop, the dishwasher door has to be left open. Is this a motherboard gone bad, a thermostat gone bad, or something else?
#2 Posted : Thursday, July 30, 2009 12:41:06 PM(UTC)
At the end of the wash cycle, does the water drain out?
drthomas123
#3 Posted : Thursday, July 30, 2009 1:11:47 PM(UTC)
drthomas123
Yes, the water drains at the end of the cycle, but the motor or pump keeps running.
#4 Posted : Thursday, July 30, 2009 1:19:22 PM(UTC)
You probably have a stuck relay on the control board. I would replace the control board.AP3965268
grm
#5 Posted : Wednesday, October 7, 2009 5:19:36 AM(UTC)
grm
I have the same problem. It's telling me to replace the motor based on the water/service test. Giving me the error code hS which is bad hall sensor. I don't know if I should replace the motor or the control board! Please help.
Thanks, gary!
grm
#6 Posted : Friday, October 9, 2009 6:02:21 AM(UTC)
grm
Control board was the issue. Thanks for the reccomendation. I was going to change the motor(hall sensor). Local Parts store had the control board for $90. not bad!
Guest (5)
