alchieboy
#1 Posted : Wednesday, January 9, 2008 11:33:55 AM(UTC)
alchieboy
Does anyone know if I will hit anything if I drill a hole through the side of this fridge/soon-to-be-kegerator?
abbie
#2 Posted : Wednesday, January 9, 2008 12:05:11 PM(UTC)
abbie
can,t see any problem. check your model # and the condenser is at the bottom of the fridge.Just don,t drill a hole between the two doors at the front,there could be a line used there to prevent exterior moisture.
alchieboy
#3 Posted : Wednesday, January 9, 2008 12:08:19 PM(UTC)
alchieboy
Thanks. I did see a schematic posted on the back of the fridge that seems to have some yoder(?) line running diagonally on the side. Is that of any concern?
