2 Pages<12
karenjv
#11 Posted : Wednesday, January 9, 2008 9:17:27 AM(UTC)
karenjv
Thanks for getting back to me. Think the oven light is a goner. We have an electrician friend coming over, so maybe he has some insight. Did giving you the numbers do any good? Maybe replacing a fuse, or wires? Appreciate you trying.
#12 Posted : Wednesday, January 9, 2008 10:49:56 AM(UTC)
Originally Posted by: karenjv Go to Quoted Post
Turn power off to oven (breaker?)
Turn power back on
With door ajar, hold light switch on while setting the cleaning function
Before function quits (stop time had to be set), push cancel button while
still holding the switch in
Turn off the cleaning controls, release the light switch
Hope that something happens
Did you do it?
What was the result?
karenjv
#13 Posted : Wednesday, January 9, 2008 11:21:10 AM(UTC)
karenjv
I sent you a reply a couple hours ago...thanks for checking
karenjv
#14 Posted : Wednesday, January 30, 2008 8:40:44 AM(UTC)
karenjv
Hi Gene,
Got the light switch from you (WPL 310345) to fix the Kenmore oven light (Model #665 4438994). Is there a specific way to remove the oven door light switch in order to replace it? It's a wall oven...need to pull out the whole thing? Thanks! Karen
#15 Posted : Wednesday, January 30, 2008 8:02:59 PM(UTC)
Hi Karen,
As you can see in the picture, there is a latch on the light switch
UserPostedImage
which is holding the light switch in place. In order to unlatch and remove the switch you have to remove the frame around the microwave which is not very simple.
Instead, you can just carefully (remove the power from the oven first) break the old switch into pieces and remove it from the frame.
Remove the wires from the old switch and connect them to the new one.
Push the new switch in place.
karenjv
#16 Posted : Thursday, January 31, 2008 9:09:38 AM(UTC)
karenjv
Thanks Gene..thought that might be the case. We'll try that (later this week) & let you know. We have another switch to replace, so might be contacting you again. Really appreciate your help. Karen
karenjv
#17 Posted : Saturday, February 9, 2008 11:45:39 AM(UTC)
karenjv
Hi Gene,
Well, it's fixed! Needed only one part, #3148669 to fix the fried switch. Thanks for helping out! Great service!!:)
#18 Posted : Saturday, February 9, 2008 12:40:55 PM(UTC)
Hi Karen,
I'm glad you were able to fix it.
Guest (6)
2 Pages<12
