the fridge had been sitting for at least a year before i got it. when i plug it in the compressor turns on and the back of the freezer gets cold but, there is no air flow into the fresh food compartment. i cannot hear a fan running and it does not get cold in the fridge. Any help with this is greatly appreciated.
thanks, Adam S.
i took the fan motor out and sure enough it had seized. i replaced it with a motor from an fridge of the the same TBX series. the fan seems to run fine. now im just waiting for it to get down to temp. hope all goes well.
thanks, Adam S.
