:cool: Fridge was not cooling properly and center panel was HOT! Pulled out and checked condenser coil (clean) but fan was not running. Ordered new fan. Before installing fan checked for voltage at conector after removing cover panel. No voltage! Currently have small fan in front of fridge blowing into coil. (Cooling great). What controls the condenser fan motor and where would that be located.
Regards!
