michaelleonardburrows@yah
#1 Posted : Monday, January 7, 2008 3:55:39 PM(UTC)
The dishwasher runs but doesn't drain. I have to siphon the water out of the tub after it finishes it complete wash cycle. The water in the tub is then still dirty, so I have to complete the job with two siphon and rinse cycles.
One more step I have to take every so often is to remove the water from the pan under the tub otherwise the washer won't allow any water in.
Any suggestions? Is it a sensor problem, or is there a separate drain pump and that's faulty?
One more problem is that Bosch won't release their circuit diagrams to me, so I'm working in the dark.
#2 Posted : Tuesday, January 8, 2008 3:33:22 PM(UTC)
The model number you provided is incorrect.
Verify and repost the model number, please.
#3 Posted : Wednesday, January 9, 2008 8:34:29 AM(UTC)
Thanks, Gene, for your response. You're right. The model number I quoted is wrong. The right one is SHX46L05UC.
#4 Posted : Wednesday, January 9, 2008 10:45:20 AM(UTC)
Possible a foreign objects inside the drain hose or the drain pump.
Also possible water leak under the dishwasher.
Remove the toe kicks and inspect for the water leaks and/or water marks.
Disconnect the drain hose from the air gap, put it in a bucket and run the drain cycle.
Post your findings.
#5 Posted : Wednesday, January 9, 2008 7:46:08 PM(UTC)
Hi Gene,
Thanks for your suggestions.
There are no water leaks on the floor. The pan under the tub collects water, however, so after about three rinse and siphon-drain cycles I have to remove some of it otherwise the tub won't fill.
There is no air gap. The drain hose runs right into the waste disposal unit. I disconnected the hose at that point and directed it into a bucket. No water came out when the washer ran.
I also blew into the end of the drain hose and could hear bubbles in the water in the tub, so I guess there's no blockage.
That covers your questions. What next?
Sincerely,
Michael Burrows
