mommy12212006
#1 Posted : Tuesday, July 28, 2009 5:12:47 AM(UTC)
mommy12212006
hi i have combo washer that the water does not come in to start the cycle can u please help me and let me know what the problem could be im not sure how long my fathers had it i think more then a year:confused:
sidfink43
#2 Posted : Wednesday, July 29, 2009 7:13:25 AM(UTC)
sidfink43
Hi Mommy
Sounds like your water valves have failed, here is the replacement part, but check to make sure the water level pressure tube is clear first and the inlet screens on the valves are not blocked.
Part number: AP4026239
If you want to check it out before you replace it, you can test it to see if 120 volts are getting to it when it is supposed to be open. Another way to check it out is to take off the water hose and fill the tub from that hose while it is suppose to be filling. If the machine starts after the correct water level is reached, the valves need to be replaced.
If it is not the valves the water level pressure switch or timer may be suspect.
Good luck, let us know if you need more info.
Squeal noise Frigidaire combo Washer/Dryer (Washer Repair)
by Guest 7/2/2022 11:33:11 PM(UTC)
COMBO WASHER/DRYER MPODEL FFLE3911QW0 (Washer Repair)
by Guest 12/11/2021 5:01:27 PM(UTC)
Kenmore Stacked combo washer wont start after heavy load :( 110.88752796 (Washer Repair)
by puppy10014 10/22/2021 9:23:07 AM(UTC)
washer/dryer combo washer won’t spin (Washer Repair)
by Bill.grieves 3/21/2018 4:08:25 PM(UTC)
GE Combo washer/dryer won't complete agitation (Washer Repair)
by dmorikawa 6/10/2016 8:54:58 AM(UTC)
Combo Washer/Dryer won't fill with water (Washer Repair)
by Ohlookatmeimjoe 9/15/2015 5:20:12 PM(UTC)
Kenmore combo Washer/Dryer P/N 41790812990 (Washer Repair)
by Sparty1$ 4/25/2015 9:01:58 AM(UTC)
GE combo washer intermittent spin (Washer Repair)
by jrschatz 5/23/2014 7:49:01 AM(UTC)
Frigidair combo washer won't shut off. (Washer Repair)
by besinger 12/23/2013 6:10:37 PM(UTC)
Combo washer/dryer leak problem (Washer Repair)
by Kawasaki 11/23/2013 10:29:57 AM(UTC)
combo washer wont drain or spin (Washer Repair)
by justair 4/13/2013 9:57:54 PM(UTC)
Maytag Neptune Combo Washer/ Dryer wont spin (washer) (Washer Repair)
by HLSerrano 3/3/2012 7:29:44 AM(UTC)
Whirlpool combo washer cold water fills slow (Washer Repair)
by TammyJJ 4/23/2011 11:13:13 AM(UTC)
Combo washer/dryer leaking water (Washer Repair)
by carsnrockmusic 12/6/2009 1:25:17 PM(UTC)
MLCE52RCS1 Combo washer/dryer problem (Washer Repair)
by bonanzaman 9/14/2009 4:46:01 PM(UTC)
