5 Pages«<345
Neal
#41 Posted : Wednesday, January 9, 2008 1:00:56 AM(UTC)
Neal
No I didn't. I check everything at the control board, The back off the connector.
Neal
#42 Posted : Thursday, January 10, 2008 1:44:36 AM(UTC)
Neal
Thanks you everyones input. I'm not going to fix it. Tired of fooling with it after 3 weeks. I'm going to replace the unit with another one. Thanks
Tyro
#43 Posted : Sunday, January 27, 2008 6:55:01 PM(UTC)
Tyro
I have a Kenmore model 66517019400. I assume the seven "clean" blinks mean the same thing on my model as the others. I tried pushing the buttons that more closely matched the one suggested earlier, but without luck. What buttons should I push on my model? Thanks.
#44 Posted : Monday, January 28, 2008 2:41:22 AM(UTC)
You have to reset the computer. Pull your service sheet, procedure should be in there. If not do the following.
Open door and within 3 seconds, press the hi temp. scrub, then energy saver buttons, then repeat. Close and latch door and hit the cancel button, should reset.
The cause of this is low water temperature, or a bad heater circuit.
hpmem
#45 Posted : Monday, March 10, 2008 12:17:41 PM(UTC)
hpmem
I have the Model 665.1602 I reset the CLEAN flashing light by using the sugestion this forum it said to:
Try Pressing:
Normal Wash - HeatedDry -Normal Wash &#8211; HeatedDry- Normal Wash &#8211; HeatedDry- Normal Wash - HeatedDry[/font] . all the lights should come on. then after a little bit. keep pressing start till disher washer gets back to normal shut down. what happen your water was to cold going into the disherwasher one time taking to long to warm up. the dishwaher went into a fault mode. the light blinks 7 times because there was a fault with your heater circuit. this should take care of it.
Guest (5)
5 Pages«<345
