2 Pages12>
karenjv
#1 Posted : Monday, January 7, 2008 9:49:19 AM(UTC)
karenjv
Even though oven is older (been in storage), been in use for nine months..after self clean, the interior light doesn't work..with door switch and manual switch. Also the indicator light for locked door remains on. Wall mount so not fun to pull out! Thanks
#2 Posted : Monday, January 7, 2008 10:47:23 AM(UTC)
Is the door still locked?
karenjv
#3 Posted : Monday, January 7, 2008 11:05:48 AM(UTC)
karenjv
No, the oven door isn't locked...just the locked light is illuminated.
#4 Posted : Monday, January 7, 2008 11:11:07 AM(UTC)
Turn off the power to the oven for a few minutes.
Push and hold the light switch on the door while starting the self clean.
Keep holding the light switch, wait for a minute and push the cancel button.
If it would not help, then I need the complete model number of the unit.
Good luck.
karenjv
#5 Posted : Monday, January 7, 2008 12:16:06 PM(UTC)
karenjv
Thanks Gene, Not sure about turning off the power to oven. You mean at the breaker? Or unplug? A few minutes before trying the "hold" procedure? I have a funny feeling the self clean fried our light source! Hate using a flashlight to see what's cookin'
#6 Posted : Monday, January 7, 2008 2:45:01 PM(UTC)
Originally Posted by: karenjv Go to Quoted Post
Also the indicator light for locked door remains on....
I do not think you can cook in the oven in that case.
You can remove the power either way. Wait a few minutes and turn it back on.
karenjv
#7 Posted : Tuesday, January 8, 2008 10:45:48 AM(UTC)
karenjv
Hi Gene...want to continue trying to fix the light. So we're on the same page, see if this is right.
Turn off the oven for a few minutes (breaker box?)
Turn power back on and while holding the light switch button on the door, set the self-cleaning into action (even with the door ajar and not locked)
Then push the cancel button for a minute or less?
Release the door light switch button, and turn off cleaning cycle
Sound right? Kenmore model#4438994 SerialXA4902599
Thanks again
#8 Posted : Tuesday, January 8, 2008 1:16:36 PM(UTC)
Good luck.
Do not release the light switch until the self clean has been canceled.
The model number you provided is incomplete.
Best regards.
karenjv
#9 Posted : Tuesday, January 8, 2008 1:41:18 PM(UTC)
karenjv
Tried to reach you this am...forum was down. To get this straight, see if this is right:
Turn power off to oven (breaker?)
Turn power back on
With door ajar, hold light switch on while setting the cleaning function
Before function quits (stop time had to be set), push cancel button while
still holding the switch in
Turn off the cleaning controls, release the light switch
Hope that something happens
Kenmore Self-Cleaning Model#4438994 Serial XA4902599
There's a 665 in front of the model # Made in the nineties, but never used
#10 Posted : Tuesday, January 8, 2008 8:11:35 PM(UTC)
You were right. Do it and post results, please.
Guest (5)
2 Pages12>
