yelrah0618
#1 Posted : Tuesday, July 28, 2009 3:49:45 PM(UTC)
yelrah0618
My drum is turning but I have no heat. The owners manual is saying that there are 2 house fuses in the dryer circuit that I should check first, but I can't seem to locate them can someone help please?
Thank you
sidfink43
#2 Posted : Friday, July 31, 2009 8:40:31 AM(UTC)
sidfink43
Take off the lower front panel and you should see thermostats/fuses. Also, lift up the top (it should release by inserting a screw driver or putty knife in the gap between the top and front at the edges) and you should access a safety thermostate.
You will need to test these for continuity with a meter, and you should find your problem.
If this is electric, make sure you have 120 volts coming to each side of the connection block.
Good luck.
