Redd
#1 Posted : Monday, July 27, 2009 11:26:13 AM(UTC)
Redd
Hello
My dryer will not get hot so I am pretty sure it needs a heating element. It was replaced about 1 year ago. My question: If your dryer will not shut off automatically can it burn up a heating element and if so what part would control the end cycle of a load of clothes. Is it possibly the dyrer thermal fuse, cycling thermostat, thermal cut-off, heating element wire or
wwwwwhhhhhhaaaaaaaatttttt!!!!!!!!!!!!!!!!!! HHHHHHHeeeellllllppppppp Me Somebody.
Redd
#2 Posted : Tuesday, July 28, 2009 11:12:55 AM(UTC)
Redd,
Does the timer moves? Would the dryer stop if you move the timer to the "off" position manually?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER4634JQ1 | AppliancePartsPros.com
Redd
#3 Posted : Tuesday, July 28, 2009 1:59:34 PM(UTC)
Redd
Yes, Gene. When drying clothes I have to manually put the dial on the off position or open the door to stop the cycle. Thanks Redd
#4 Posted : Tuesday, July 28, 2009 7:43:25 PM(UTC)
Looks like the timer has gone bad. Do not rush with the heating element unless you've checked it for continuity and it reads "open". Might be a bad timer caused it not to heat as well.
- The timer Part number: AP3131541
Redd
#5 Posted : Wednesday, July 29, 2009 11:18:06 AM(UTC)
Redd
Thanks Gene,
I will check this weekend and see how things work out.
#6 Posted : Wednesday, July 29, 2009 12:28:21 PM(UTC)
Guest (4)
How to remove shredded venturi tube? (on thermador gas range) (Oven Repair (including Ranges and Cooktops))
by samjones4 12/16/2014 8:56:29 PM(UTC)
washer is shredding clothes (Washer Repair)
by busterhead 1/11/2014 6:43:17 PM(UTC)
Inglis Washer Shredding Gasket? (Washer Repair)
by Dargon 12/17/2012 5:56:47 AM(UTC)
Washer shredding my clothes (Washer Repair)
by barnicmat 1/2/2010 8:47:56 AM(UTC)
