afishe
#1 Posted : Monday, July 27, 2009 5:35:06 PM(UTC)
afishe
I have a 2 yr old Kenmore/Whirlpool dishwasher (model 665.13769k602). The handle/latch on it does not have any "spring action", feels loose, and will not lock into place (thus cannot use dw). I opened the control panel and removed the door latch assembly. There's three plastic parts (actuator latch, latch bolt, handle) and I can't figure out which is broke or needs to be replaced (or maybe the switch needs replacing?). Are there supposed to be springs inside (because I don't see any), or what gives the handle that spring action feel when you pull on it with normal use?
I'm hoping this is an easy fix and I can repair myself.
afishe
#2 Posted : Tuesday, July 28, 2009 5:26:23 AM(UTC)
afishe
I now realize how dependent I am on my dw.
Would pictures help anyone? Need more details?
jjpeach
#3 Posted : Thursday, July 15, 2010 3:01:23 PM(UTC)
jjpeach
I put it back together and slammed the door shut and it stayed shut, don't know if I will be able to open it when wash cycle is done? Same problem as you!
allyfl
#4 Posted : Saturday, July 17, 2010 6:19:56 AM(UTC)
allyfl
I have a Whirlpool also that has the same problem. Any advice would be great. I'm unsure as to what part to order and what to do with it once I get it!
Jeff RI
#5 Posted : Wednesday, February 20, 2013 10:11:58 AM(UTC)
Jeff RI
I made these repairs on a GE dishwasher, but it sounds like the same issue. Refer to this post that I made with a few photos to go along with the other posters description of the repair. Hope this helps.
http://forum.appliancepartspros...r-spring.html#post800475
