I have replaced the oven sensor and I still get the F3 error code.
Check the oven sensor resistance at the control board plug. It suppose to be about 1100 Ohms at the room temperature. If the reading there is wrong, check the sensor resistance at the sensor plug and the wire harness. If there is nothing wrong then replace the control board. - The part number for the control board is AP2150433 - Here are the break down diagrams for the Frigidaire range Model FEF368CCTAGood luck. Gene.
Be sure to hard wire the connectors. The glass nuts should have been included in the package. wrench:)
