lalexander
#1 Posted : Monday, January 7, 2008 5:43:34 PM(UTC)
lalexander
the waasher was fine and then all of a sudden the washer made a load sound and then it just stop working.. when you turn of the washer to any cycle it sounds like the ball bearings are sitting at the bottom of the washer tub.. spin will not go again.
#2 Posted : Tuesday, January 8, 2008 2:34:41 AM(UTC)
Probably a bad motor coupler, just pull out pump and motor and check.
Guest (4)
