01brukat
#1 Posted : Friday, July 24, 2009 10:25:12 PM(UTC)
01brukat
Water keeps coming in from port on left side.
This filled the tub area, and caused the unit to leak out every where.
I manually set the switch to off.
Emptied most of the water out manually, and set switch to just past
rinse cycle. This got rid of the rest of the water.
Q. would this be caused by a faulty control unit or what.
#2 Posted : Sunday, July 26, 2009 3:02:38 AM(UTC)
Your timer is probably bad. It is supposed to fill the dishwasher for between 40 and 100 seconds only. If not, order a new timer AP2909625
