maximum destruction
#1 Posted : Sunday, January 6, 2008 10:04:14 AM(UTC)
maximum destruction
Was using my washer this am and did a few loads. on the last spin cycle of the last load most of the water drained into my laundy tub, but it has stopped draining and ther is a different sound to the unit not overly load just a different sound, Any info help greatly appreciated.
Maximum Destruction
#2 Posted : Monday, January 7, 2008 8:20:52 AM(UTC)
What kind of noise it makes?
Does the motor run?
Does it agitate and/or spin?
maximum destruction
#3 Posted : Monday, January 7, 2008 1:46:43 PM(UTC)
maximum destruction
its kind of a louder hum, it agitates and spins. With the diagrams from the other post you sent, I am going to haul the box off and check the pump and the in/out lines for foreign material.
Maximum
maximum destruction
#4 Posted : Monday, January 7, 2008 2:35:32 PM(UTC)
maximum destruction
Thanks for the info Gene. I hauled the housing off and checked the incoming and out going lines from the pump , and sure enough there was a toddlers blue Old Navy sock stuck there. Checked a couple cycles and seems to be draining fine. We will put her to the test shortly.
Thank you ,
Maximum Destruction ( my little boy came up with this name)
#5 Posted : Monday, January 7, 2008 2:46:50 PM(UTC)
I'm glad you were able to fix it.
Guest (4)
Roper washer will not drain or spin? (Washer Repair)
by Burns5150 9/3/2011 6:50:17 AM(UTC)
