danlo
#1 Posted : Thursday, July 23, 2009 8:52:31 AM(UTC)
danlo
Seems to be a common question, why do I only measure 34 to 35 vac at the black and white wires going to the icemaker from the sensor board?
#2 Posted : Thursday, July 23, 2009 3:57:26 PM(UTC)
danlo
#3 Posted : Friday, July 24, 2009 6:26:34 AM(UTC)
danlo
so your saying that 35vac is the correct voltage that is supplied from the sensor board to the ice maker? So the ice maker doesn't use 120vac to turn the motor or defrost the ice tray to release the cubes for the next cycle.
