1999 whirpool refrigerator, my water dispensor is dripping water my ice maker works fine is it the solenoid what is the part # where is it located and how do i change it
Quote:where is it located Pull the refrigerator out and take a look on the back of it. It is located in the bottom corner and has the water line connected to it. Water Valve LocationIf you have good water pressure then I would replace the water valve (solenoid). Water Valve for Model ED25TQXFN01
