I have a Frigidaire FRS23LH5DS0 side-by-side. The other day, I reset my circuit breaker for an unrelated reason, and now the refrigerator is not cold. Both fans are running (the condenser and evaporator fans), but there is no cold air in the fridge or freezer -- it has been two days now, and both are room temperature. The compressor is room temperature. All lights are working.
Is there a fuse in the fridge that I could have blown when I reset the circuit breaker? Any thoughts? Thanks!
How long time has been between the breaker was "off" and back "on"?
Unplug the fridge for a couple hours. It could help.
There are no fuses in the fridge.
Good luck. Gene.
