Big Guy
#1 Posted : Monday, January 7, 2008 9:02:07 AM(UTC)
Big Guy
I Installed A New Sink For My Daughter. I Changed It From A Bottom Mount To A Rim Mount Sink And The Air Gap Is Leaking Water. Should This Be Leaking Water???? Or Is The Air Gap Defective???
#2 Posted : Monday, January 7, 2008 11:41:04 AM(UTC)
Did you replace the garbage disposer at the same time?
Big Guy
#3 Posted : Monday, January 7, 2008 2:35:44 PM(UTC)
Big Guy
No, I did not replace the disposal but I did put a new drain line in from the air gap to the disposal
#4 Posted : Monday, January 7, 2008 2:48:48 PM(UTC)
If water shoots out of the air gap then some thing is wrong with the hose from the air gap into the g/d.
air gap leaking very small amount of water (Dishwasher Repair)
by esteinhoff 3/4/2010 3:40:35 PM(UTC)
